Rust converter or undercoating
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Someone told me that I can apply rust converter underneath my car to help prevent it from rusting out on me, is that true? I thought that undercoating was really the only way to solve that problem.
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Re: Rust converter or undercoating
How bad is the rust?
Buy some POR-15.
Buy some POR-15.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The rust coverter works very good on surface rust. If the rust has already pitted the metal, the metal needs replaced.
Undercoating wont stop the rust, it only hides, or prevents it before it starts.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Car: 91 Trans Am
It only looks like surface rust to me. My mechanic said that he noticed the rocker panels are starting to rust so he said to definitely take care of those before they get any worse. The weather has been nicer so I will get under there as soon as possible. Thanks for your help.
POR-15 is not supposed to be used in sunlight. It is UV sensitive. If the outside of your rocker panels are starting to go a body shop and get them repainted.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
antonio, auto, bad, body, car, converter, converters, converterundercoating, convertor, ratings, rust, san, tx, undercoat, undercoating
The proper way to do it is to get under there with a wire wheel and a sander, clean off as much rust as possible, then prep and coat the area with POR-15 (or similar product) as per their instructions.
