Firebird headlight options
Old Mar 29, 2007 | 11:49 AM
Spiers's Avatar
What options do us Firebird/TA owners have for headlights?...all I know of is Silverstars and cool blues...I want some good bright headlights with the blue tint to them. Is there a conversion available?
Old Mar 30, 2007 | 04:44 PM
Spiers's Avatar
Re: Firebird headlight options
What about these I found on Ebay?...
http://cgi.ebay.com/ebaymotors/77-82...spagenameZWDVW
Old Apr 2, 2007 | 08:50 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I got the conversions from Hella when they had them. Not sure if they still do. Then I found a nice set of higher wattage H4 bulbs to install into the conversion housings. Along with the higher power bulbs, I upgraded my headlight wiring to use relays so that the power is drawn right off the battery instead of going all the way through the headlight switch...standard headlight wiring upgrade.
When I first turn mine on...they are annoyingly blue. For about 45 seconds. As they heat up they slowly turn white. After about a minute, they are pure white with a hint of blue at certain angles and are plenty bright for me.
I also installed Pilot Ultra White H3 bulbs in my fog lights. Those suckers are bright too. Here is a pic with one Pilot H3 and a regular halogen H3. I had a rock take out my one side...so I just put a regular bulb in until I replace both my foglight units. Again...slight blue tint at certain angles.
you should be able to tell which is which....
At night...
The only good one I have of my headlights on...middle of the day in 100% sunlight.
Justin
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
