Advice - Hood insulation
Old Mar 30, 2007 | 12:08 PM
PLaSMaN's Avatar
Car: 87 Camaro IROC-Z
Engine: LB9
Hi everyone, i just wanted to know if there is any reason i should keep the hood insulation under my hood ? it's getting really old and if it is only a question of acoustics, i'll be removing it for sure.
Thank you !
Old Mar 30, 2007 | 12:12 PM
R4][N_M4l{3R's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
Re: Advice - Hood insulation
I took mine out last year and have yet to have a problem.
Old Mar 30, 2007 | 12:23 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
You can buy replacement ones for a low fee. Like under 25 dollars. The insulation does provide for a quiter ride.
Old Apr 2, 2007 | 08:49 AM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
I ripped mine out, it was all torn up and sagging all over the bay. Don't really know what kind of sound it would deaden, only sound from my car is from the exhaust
Old Apr 2, 2007 | 03:04 PM
TREK's Avatar
Car: 1979 vette
Transmission: th350
also protects your hood from hi temp that may cause you paint to fade. i also took mine off cause it was falling apart and noticed that the under side of the insulator looked new i was planning on trying to flip it and reinstall it but sold the car before i could try this. if the holes line up give this a try.
Old Apr 3, 2007 | 01:40 PM
PLaSMaN's Avatar
Engine: LB9
Ok, i will remove it and decide then what to do, thank you very much for your replys !
Hotrodboba400
Dec 10, 2019 07:07 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
