How hard are your doors to close? - Shaved handle problems...
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
So I shaved my door handles and installed whatever the kit is from Summit a while ago. The problem is my doors are pretty hard to close now. When I did the poppers I also put new weatherstripping on the doors though which was a little over a year ago. So my questions is are these doors normally hard to close or is it the poppers because I have never opened or closed my doors without the shaved handles. Second, does anyone make a really light popper if it is the case?
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: How hard are your doors to close? - Shaved handle problems...
i bet you bought aftermarket weatherstripping, i have the same issue, my doors are hard to close after the aftermarket weatherstripping
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Mine still has its original weather stripping on it and i have to give it a little extra push to shut it.
Car: 83 camaro
Engine: 383 stroker
Transmission: TCI 3spd manual
yeah my driver door requires a bit of a push to close it properly, the passanger side is a little better. I always thought my bushings were just going bad. But then again our cars have them big heavy doors
Car: 85 Iroc-Z
I think that my problem is my door bushings like urmomshot77 said.
diana227vegas
Jul 8, 2016 12:27 AM
