Help with Glazes and body filler
Old May 11, 2007 | 02:37 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I see there are a number of glazes to use on a car. 3M has there two and Meguirs has one as well. Which one is best for a newly painted car?
3M has perfect it durable glaze- made with siliconethat can be used by hand or buffer.
3M also has one for application by hand only made without silicone or wax.
Meguis I am having a hard time finding out about. 3M makes this in an Imperial series as well as a perfect it 3000 series.
Also, which body filler is best to use? Evercoat Z-grip or Bondo, and what kind?
Old May 11, 2007 | 08:38 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
Re: Help with Glazes and body filler
i use perfect it by 3m good stuff, presta is also a great product. you do need the systems if you can, i use a compound and then a swirl remover then a hand glaze final inspection polish, just be sure anything you use says polish and not wax and your good to go. no wax for 6 months. polish within the windows that are spelled out in the tech sheet for the clear your using. my hok is 12 hours.
evercoat....... great stuff
jeff
Hotrodboba400
Dec 10, 2019 07:07 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
Kenwood
Sep 4, 2015 05:50 PM
