Hood Help
Old May 23, 2007 | 12:43 PM
Camaroracer1258's Avatar
Engine: 383 stroker
Transmission: turbo 350
Hood Help
I have a 2.5" Fiberglass hood on my '85 camaro. I have a buddy that has an '84 and he uses a low compression strut for his fiberglass hood so that the hood goes down easy yet it is able to keep the hood up as well. Does anybody know where I can get these struts with a low compression?
Old May 23, 2007 | 01:06 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Hood Help
Lucky for me my old hood (IROC Hood Weighs 61lbs) it blew my struts....and now with my Daytona Hood (2.5" Cowl Weighs 40lbs) uses them with ease.
So I would say your best bet is either ask your buddy or junkyard struts...
P.S. Let me know about the low compressions struts though as I wouldnt mind new ones....
Old May 23, 2007 | 01:31 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Re: Hood Help
I think I saw some low-comp struts in a jegs mag.
Old May 23, 2007 | 02:31 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Hood Help
FOUND THEM.....FOUND THEM.....FOUND THEM.......FOUND THEM.....
http://www.3sx.com/store/comersus_vi...dProduct=24379
They Have High Tension And Low Tension
P.S. Check for fitment first, as these are quick release and bolt right into the hood instead of on the hinge.
Old May 23, 2007 | 03:07 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Engine: 305 V8 carb'd
Re: Hood Help
I got mine at advance
http://www.partsamerica.com/productd...pe=565&PTSet=A
Old May 23, 2007 | 03:30 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: Hood Help
Originally Posted by 86-Iroc-Z
Do you have a fiberglass hood?
If so they dont put to much tension on the hood?
I had a pair of new stock replacements and they would barely let me close the hood without maybe cracking the hood. I put my blown ones in and boom...hood goes up easy as hell and down pretty good...still a little strong for me but they'll do.
Old May 23, 2007 | 05:38 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Re: Hood Help
Yes, fiberglass cowl.
It goes up & down very smooth & easy. I just put them on yesterday.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
