Window goes down too far
Old May 24, 2007 | 06:05 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My passenger side power window goes down too far. I can't seem to find the stop for it. How can I adjust this? Its doing the thing where it goes down too far and falls toward the outer part of the door, then binds going back up.
Old May 24, 2007 | 11:49 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Re: Window goes down too far
The stop has broken off.It's probably in the bottom of the door.You need to fabricate a new one.You can use a bolt in place of it.
Old May 25, 2007 | 09:50 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
He is right. Take the door panel off, look at the bottom of the window, you will see where there is supposed to be a metal clip holding a rubber stop to the bottom of the window that hits the bottom of the door to stop it from going all the way down.
Old May 25, 2007 | 10:54 AM
camarokracker's Avatar
Car: 86 Camaro Sport Coupe
Engine: 377 sbc
Transmission: WC T-5
Axle/Gears: 3:70 Ford 9" Rear
ok.. clal me stupid but i have the same problem ... but i cant see where there is suppose to be a metal clip with a rubber bump stop???? maybe i am not looking in the right area.. or i dont know what i am looking for
Old May 25, 2007 | 11:27 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I did not find the stop, but I did find where it mounts and hits the bottom of the door. I cut a little square of rubber and attached it to the bottom of the door and all is good now.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
