Hood shocks - What am i missing ?
Car: 87 Camaro IROC-Z
Engine: LB9
Hi everybody !
I ordered and installed a pair of Strong Arm 4422 Hood shocks and the hood doesn't stay up more than with my old and worm shocks. Am i missing something for the hood to stay up ?
I looked at some underhood pics on this board, and i didn't see any additionnal springs between the 2 pairs of hood pivots. maybe there is a circular spring somewhere that i am missing.
Could anybody guide me ? Maybe a pic would be helpful.
thank you very much !
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Re: Hood shocks - What am i missing ?
All I can say is be sure you ordered the correct shocks.
The steel hoods on most thirdgen's weigh an awful lot (50-80lbs?), while the aluminum T/A and Formy hoods weigh about 1/3 of that. Perhaps you mistakenly received the shocks for the al. hood ?
Engine: LB9
The 4422 shocks are indeed the ones for the steel hood, but the shocks themselves are not identified, only the bag, so yeah it could be anything in the 4422 bag... that's sad
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
I ordered a set of hood shocks off ebay for 28.95 plus shipping ( link to auction )
sold by ez-parts . . .genuine Stabilus hood shocks - they work better than the day I bought the car.
I know this doesn't help much -- but if you were to return the ones you received you might find these are a better replacement.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've seen fiberglass camaro hoods that were suposedly stock, but never an alum hood.. Dang, learn something new every day!
-- Joe
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Yep, aluminum hoods were on every 82-83 T/A with functional cowl induction that I have seen. The one I have couldn't weigh more than 25-30 lbs.
I may be mistaken about the late model formy's -- they look similar enough, but I've never actually checked it out.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Stock IROC hood weighs 61lbs....my Daytona (I havent weighed it) is said to weigh between 35-40lbs....I am using BLOWN stock struts....and they hold like their brand new....just need the clips for them so my hood doesnt wobble back and forth...GL
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
my Daytona Turbo hood is much lighter and can work on older or used shocks just fine.
Car: 1989 Firebird
Engine: 5.7 LS1
Most part stores carry the "shocks" for the hood. I bought mine at advance 4 years ago and they are still holding. Put them on in the parking lot so I knew the worked. I think they were then around 25-30 bucks but well worth not having to put a pair of vice grips on the old shock to hold up the hood every time I needed to work on it.
Car: 89 Iroc Convertible
I always get mine from the junkyard.They charge 2 bucks apiece for hood or hatch shocks.Best part is that you never get bad ones cause you can already see them at work.I grab them whenever I can
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
