Front bumper cover removal
Old Jun 11, 2007 | 09:47 PM
heavrolet9894's Avatar
I have a 88 Iroc and I am trying to take off the front bumper cover to install a new header panel (headlight mount) but I just can't figure out how to get it off. If anyone could break it down for me I would appreciate it.
1988 Iroc-z 350 TPI, T-Tops, 9 bolt disc brake rearend, in need of serious restoration
Old Jun 11, 2007 | 10:11 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: Front bumper cover removal
Hope this helps
https://www.thirdgen.org/forums/body...bumper+removal
Old Jun 11, 2007 | 10:35 PM
That helps a lot. Thanks
Old Jun 12, 2007 | 12:01 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
3 bolts on wither side that attach the GFX to either fender, 6 or 8 bumper clips underneath in which you pull out the center(moast people just seem to break them though) 2 nuts on the hood latch bracket that join it to the headlight bar, and by the headlights, and finaly four bolts on both side inside the fender which join the edges of the fender and bumper cover.
Old Jun 12, 2007 | 12:11 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
You don't need to remove the bumper cover to replace the panel, if you loosen it at the top you can slip the old one out and pop the new one in.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
