triangle door glass seals, difference in them from early to late ?
Old Jun 21, 2007 | 09:24 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
it seems there may be a difference in the triangle door glass seals from early ones to later years ones
from what i have seen in some posts anyways
is this true or not ?
if so then what years ? and whats different about them ??
looking to learn something new here if possible
and i ask becausei have a clean pair of these off an 88 camaro i need to use for my 82 t/a
thanks
Old Jun 22, 2007 | 05:49 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: triangle door glass seals, difference in them from early to late ?
there is a difference in design (the way it mounts to the door) the early ones i beleive are 82-84, then 85-92 are the other, so the ones you have will most likely not work in your 82
Old Jun 23, 2007 | 02:32 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I dont think there is any difference.I have noticed that there is a 1 piece version where the corner triangle is all integrated with the seal.Ive replaced the window seals on my 82 camaro and the replacements which came from an 89 f body just slid right on.
Old Jun 23, 2007 | 05:57 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah thats the difference the newer ones have the long channel for the windows, i tried using the older style and it would not work, dont remember why
Old Jun 23, 2007 | 08:46 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
My 92 parts car had the one piece setup which was a lot nicer in the way it sealed compared to the old 2 piece one on the 88. Made a difference in water getting in and wind noise. I didn't have any problems installing them that I can remember.
Old Jun 23, 2007 | 09:58 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
anyone have a straight for sure answer on if the 88 ones i have will mount in my 82 doors?
thanks
Old Jun 26, 2007 | 03:01 AM
Kandied91z's Avatar
yes they are different. what does it matter if it works for you and cost effective. if you were restoring a show car you would know to go with the older one right.
use what works.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
