What should I use to...
Old Jun 22, 2007 | 02:27 PM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
I want to cut holes in a billet grill I have for my clear foglights, but I really don't want to mess it up. My goal is to have them mounted completely flush with the grill. I'm tempted to use a dremel with a cut-off disc to cut through the first couple slats, and then use a small hack saw blade to cut through the rest. The problem I forsee with this is that I'd have to use the dremel/cut-off disc at a bit of an angle, which is something I want to avoid. Also, the slats are very close together meaning two slats would have to be cut at the same time, adding to the risk.
Does anyone know of a tool or method that may work better? Thanks, Josh.
Old Jun 23, 2007 | 03:22 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: What should I use to...
It would look good, just having them behind the grill. Might affect the light alittle but you will get used to it.
DuronClocker
Oct 25, 2004 03:06 PM
3rdGenSS
Aug 25, 2004 05:12 PM
Maverick H1L
Aug 10, 2004 12:34 PM
TheGreatJ
Jul 21, 2004 06:13 PM
Demon Z28
Pacific Northwest Region
32
Jun 25, 2001 08:05 PM
