Firebird/camaro floor question.
Old Jun 23, 2007 | 03:31 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Alright i need to replace the floor in my camaro (89 rs) the drivers side. But i very soon might be buyign a 91 firebird. its got some nice parts on it so i plan on stripping it down and sellign the parts off. But now im wondering if i can cut the floor our abotu a foot square where your feet are. Do they both have the same floor? or is the camaro diffrent from the firebird. I dont want to spend the time to bend up the floor if i can just take the time and cut out the peice. Ive never been in a 3rd gen firebird to knwo how its set up floor wise. so any help sweet. I dont knwo if this is a dumb post or not. Seems good to me.
Old Jun 23, 2007 | 05:42 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: Firebird/camaro floor question.
they should be the same floor pan.. f body.
Old Jun 23, 2007 | 10:23 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I kinda have some criss-cross questions of the same nature if the orginal poster doesnt mind.
What about rear bumper bracing? Friend needs one, all the camaro ones are rusted, but the yard has some good firebird ones.
Also, will the rocker/door GFX from a bird physically fit dimension wise on a camaro? Bolt patterns may be different?
Old Jun 23, 2007 | 11:00 PM
naterman35's Avatar
Engine: 305--
Axle/Gears: 2.73--
Oh i totaly dont mind. I like knowing these things incase it happends to me also. especially with the GFX because one of mine is broken and on this donor car th are still in good shape.
Old Jun 26, 2007 | 02:59 AM
Kandied91z's Avatar
gfx are different... rear bumper bracing aftermarket metal is cheap. i think around $40. check www.rockauto.com for example. the plastic honey comb. now that's expensive if you need to replace it.
yes same, your good to go. for flat section i just pick up the same size dia. sheet metal and rework it. if you do a good job it can look nice and much better then a rusted floor.
Last edited by Kandied91z; Jun 26, 2007 at 03:00 AM. Reason: Automerged Doublepost
Old Jun 27, 2007 | 12:40 PM
Dale's Avatar
Engine: 350 S-TPI
Originally Posted by Kandied91z
gfx are different... .
So they wont bolt up? Crap
LC2 TECH
Oct 13, 2015 11:53 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
Ian Irvine
Sep 4, 2015 08:08 AM
