Need help replaceing a window
Old Jul 2, 2007 | 01:55 PM
Denial's Avatar
Car: 84' z28
Engine: Built 350 SB 4 Bolt, Bored .30 Over
Sorry if this is in the wrong section, i wasnt sure where to put it.
Anyway, some punks around my neighborhood broke out my window in my 84 z28, its under a car cover so im not to worried about rain getting in, but i am worried about moisture and such. I have a 92 RS thats being parted out currently that im going to grab a window out of and put in the 84. Question is, how do i go about doing this? Could somebody give me an indeoth guide or explanation on how to replace a window, starting with removeing the door pannel and then going from there to finish. Also how dificult of a job will this turn out to be?
Thanks for the help guys, im trying to get this replaced asap, its been without a window now for about a week.
Old Jul 3, 2007 | 08:07 PM
Denial's Avatar
Car: 84' z28
Re: Need help replaceing a window
nobody?
Old Jul 3, 2007 | 10:41 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
look in the tech section under converting manual windows to power windows.........same procedure in taking the3 glass out and puttin the new peice in..should take about an hour or so
Old Jul 3, 2007 | 11:15 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
The rivets are a PITA. I've swapped windows before, and it's a very straightforward process, but it's time consuming. You have to remove the rivets, carefully remove the window, put the new one in, and attach that. I chose bolts to attach it, however I don't believe that was the best idea, since now it rattles slightly (even after loctite-blue). And yes, I chose loctite-blue because if I used the red stuff, that would defeat the purpose of having something removable like a bolt in there anyway.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 21, 2015 01:54 AM
Wylecoyote08
Aug 14, 2015 08:28 AM
