Newbee question
Old Jul 21, 2007 | 08:48 AM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Newbee question
Question 1 : which should i use to clean my gun after spraying urethane ?
Acetone or Laquer thinner??
Question 2 : Are the little baggie things that go inside the siphon cup for easy clean-up a good idea or not...
I am a first time painter getting ready to experiment with a urethane i got off the internet from the Kustom Shop called Hot Rod Flatz. It is pre-flattened and ready to shoot. I thought since my son likes the old school flat black rod look, this would hold up better than black primer...Oh well we will see
Thanks for any help !!
Old Jul 21, 2007 | 12:54 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Newbee question
I vote lacquer thinner, never tried acetone though.
Old Jul 21, 2007 | 06:58 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: Newbee question
i use lacquer thinner..
Old Jul 21, 2007 | 07:04 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: Newbee question
Laquer thinner, depending on the quality of the gun, I take it all apart and clean it. But if it's just a under 100$ gun, clean the bowl, tip, run laquer thinner through it with the tip on, and off, and leave the tip in the bowl with laquer thinner.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
