Small fender dent, please help
Old Aug 12, 2007 | 05:26 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
OK, I some how got 2 small dents in my passenger side fender, one looks ike a golf ball hit it and the other is a lot smaller than it, Im not much of a body guy, but I was wondering the easiest way to pop these out? The paint was not affected by the impact so I have no clue how it got there, Here are some pics
The bigger one is a lot more distince but the smaller one is more visible in the third picture I posted, Thanks In advance
Old Aug 12, 2007 | 05:41 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Small fender dent, please help
1st try to access it from behind. Maybe from inside the hood area in the access hole. If you can get to it, a metal rod (strong and with a hook or otherwise rounded end) might be able to massage it out. Ive also seen a video about using compressed air and heat. Heres the theory....get a heat gun or hairdryer and a can of the compressed air (found at computer stores for blowing out the inside of your computer), heat the metal with the heat gun or hair dryer (careful with a heat gun not to damage the paint) for about a minute or less, then quickly apply a spray of the compressed air (hold upside down so the liquid comes out), and then wait until the icy coat dissapears. http://youtube.com/watch?v=miNykNl-0NM
Old Aug 13, 2007 | 05:50 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Id recommend calling a paintless dent removal company. Its never going to be prefect without doing body work and a repaint. PDR will get it out 99% of the way. However this isnt something a first timer should attempt, its not the easiest.
Matt
Old Aug 13, 2007 | 06:02 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I think im going to attempt it myself first, Its not as dented in as it looks in the picture. I think now that its possibly from when I had my oil changed and the guy leaned over the car and his knee hit there. If that fails i will take it to a shop and have it fixed.
Old Aug 23, 2007 | 05:29 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Ok, I Ran into a friend from highschool that was always into autobody and paint and He said that I could either pop it out from under with like a flat rubber hammer, but what he would do is get some dry ice and put it in a bag and then wrap it in a rag and stick it on there and it would suck it out. has anyone ever done that or heard of doing that?
Old Aug 23, 2007 | 05:38 PM
84noname's Avatar
to get at it you really need to remove the fender.i personally would do the paintless dent thing if u can afford it, since the repaint will be something you cant do your self, and u might pop them out from behind but the paint might chip, usaully i try n pop em out if not i just use bondo
Old Aug 23, 2007 | 05:42 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Well he said if I did the dry ice thing that it would suck it out to about where it should be, but it might take a couple times and that it shouldnt affect the paint unless i stuck straigh dry ice to it and he said a lot of the dent removal places do the same thing on smaller dents. I just wanted to see if anyone else has heard of this, because its not as bad as it looks in the pictures I posted its just the glare makes it look worse.
morrow
Jan 13, 2024 12:29 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
xbazzarex
16
Oct 6, 2015 08:42 PM
hydrolic144
Sep 8, 2015 06:59 PM
