What do you think?
Old Aug 17, 2007 | 08:57 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
What do you think?
Just refinished this rim, what do you all think??
Attached Thumbnails What do you think?-before.jpg   What do you think?-after.jpg
Old Aug 17, 2007 | 09:02 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Re: What do you think?
The pretty damn good! waht did you do to them?
Old Aug 17, 2007 | 09:19 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Well, I started out dry sanding it with 180 grit sandpaper and then wet sanding with first 320, then 400, then 1000 grit sandpaper.Then I went over it with a rubbing compound and finally two coats of wax.
Its pretty time consuming, I spread it out over a few nights.
The hardest most tedious part is just the dry sanding with 180 grit
to get the clear coat and the factory machining marks out.
I think its well worth it though.
Old Aug 18, 2007 | 09:06 AM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
You can get a clearcoat remover that will make it easier on you for the 180 grit sanding. I here its pretty messy stuff though. I don't have a place to use it so I just used a little elbow grease on that part.
Old Aug 18, 2007 | 09:14 AM
v10viper04's Avatar
Engine: LT1, L99
I'd have to say that you did a really good job though! Keep up the good work!
