Por 15 question
Old Aug 21, 2007 | 09:09 AM
camaro88sc's Avatar
Car: 1988 Chevy Camaro SC
Engine: 305 TBI
Por 15 question
Has anyone ever used por 15 on the roof? and if so do you have to paint a top coat on top of the por 15?
Old Aug 21, 2007 | 09:24 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Por 15 question
I dont know of anyone that has used it on a roof... not sure why you would. However, if you intend to use Por-15 in an area that is exposed to sunlight, you will need to top coat it. Por-15 tends to fade due to not having any UV protection. You need to follow Por-15's steps and guidelines to top coating it.
Would be easier to just use some urethane paint or base coat clear coat or something. Por-15 is better for floors, suspension parts, underhood stuff, etc in my opinion.
J.
Old Aug 21, 2007 | 09:49 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: Por 15 question
While you could do it, it would be sort of a waste. If it's painted good with regular body paint, it wont rust since it's a flat surface exposed to sun and wind. Por-15 is better for say, your T-top weatherstripping channels etc.
Old Aug 21, 2007 | 08:23 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Re: Por 15 question
I did my upper frame rails with por-15 silver.. and since I didnt have the fenders on, and it was exposed to the sun, keep in mind the car is in a garage.... after a few weeks, the silver turned green on me. Still works... but it changed colors.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
