Aligning rear hatch GLASS, not metal
Old Oct 10, 2007 | 05:28 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I havent seen a whole lot of posts on here about rear glass alignment, only the metal portion that sticks out. I have to adjust that as well, but for now I have to get the glass centered. Mine is shifted over about 1/8" to the right, damn near rubbing the body panel, where as I can almost fit my pinkey in between the body panel and glass on the left side. I completely loosened the hinges at the top (inside and outside nuts), and even with a friend of mine pulling as I tightened I cannot make a dent! I noticed someone said the hatch struts will work against you if they are still attached, but is it possible to align the glass at all, or only the metal portion? If its not, then I either have a warped glass, or even better a warped car
Old Oct 10, 2007 | 06:09 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
Re: Aligning rear hatch GLASS, not metal
drill out the holes, and do it with the struts off
Old Oct 10, 2007 | 06:28 PM
spills's Avatar
Car: 89 RS
which holes, the ones on the body? Or does the glass have metal reenforcements I can enlargen as well?
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
