Did any 91/92 clusters ever have white numbers?
Old Nov 11, 2007 | 06:20 PM
cdoyle's Avatar
I had a cool idea for my 91/92 style instrument cluster using LEDs, but it looks like the yellow numbers are painted on the front of each gauge, and doesn't appear to be a way to get it off without ruining the gauge.
Did any 91/92 style cluster ever come with white/clear numbers?
or does anyone know of a way to totally swap out the factory face on the gauge with a new one?
Old Nov 11, 2007 | 06:33 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Did any 91/92 clusters ever have white numbers?
I don't believe any of them came with white numbers,I'm 100% sure ,but not 110%.I don't know about changing it,but you could possibly remove the clear plastic part on the back and clean the yellow paint off with some thinner,but that would probably damage the black part of the gauge face.Maybe you could find a gauge piece in a junkyard and do some experimenting.I would deff. go that route,I know you've done alot of work on this dash setup,and you don't want to destroy anything.
Old Nov 11, 2007 | 06:50 PM
cdoyle's Avatar
Ya I'm pretty bummed that the yellow paint seems to be painted on the front of the gauge, instead of from behind. If it was behind, I thought I could use some acetone or something to get it off, without any of my work showing on the front.
I'll think of something, I had a cool idea for LEDs on this!
Old Nov 11, 2007 | 07:53 PM
cdoyle's Avatar
OK, I thought I remembered seeing something
https://www.thirdgen.org/forums/post...2-post182.html
According to Camaroboy, these were out of a V6.
Can anyone else verify that the V6 models had white lettering?
If so, is there a way to make the V6 tach work in a V8?
Old Nov 11, 2007 | 08:22 PM
cdoyle's Avatar
I just remembered, this cluster style was also used in 90 too.
Maybe the 90 V6 has the white lettering?
Anyone have a 90 V6, what color is your cluster?
Old Nov 12, 2007 | 11:22 AM
ParkerTPIz's Avatar
the 90-92 clusters were all yellow.....that was part of the "new package" from mid 90-92. ive seen some that almost look white though, but its just from sun-fading.
u could possibly just buy an overlay
Old Nov 12, 2007 | 11:35 AM
cdoyle's Avatar
An overlay won't work because the yellow writing will still be under the white. So when lit up the yellow will still show through. I think the only way to do this woudl be remove the face off the gauge all together and then put an overlay on. Not sure how hard this will be tho
I might just try and also try and remove the yellow, and see what happens. If I mess it up, I can buy another cluster
okfoz
Sep 17, 2015 10:30 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
Springster
Sep 13, 2015 01:38 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
90formulaVortec
Sep 8, 2015 12:42 AM
