91-92 Ground Effects Removal
Old Dec 21, 2007 | 12:34 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
Hi all
I'm new to this field and I'm converting my 91 FB to a Knight Rider replica, everything going smoothly so far except that I can't figure out how to remove the mounting piece for the side ground effect under the door! It's on there pretty solidly... please don't tell me it's welded on 'cause I can't weld!
Also is anyone interested in my nose and GFX after I get them all off?
Cheers Tom
Old Dec 21, 2007 | 06:21 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 91-92 Ground Effects Removal
The piece that attaches to the door is bolted from inside, pull the door panel for access
The rockers are bolted thru the front fender, rocker sill, under the rocker sill and infront of the rear wheel accessed from the interior
There is a sheet metal support bracket that is welded onto the rocker. It can be cut off and ground flat (no harder than any other body work you will be doing)
And Im interested in the nose and gfx, PM me with what you have, price and location please
Old Dec 26, 2007 | 11:29 AM
RPM WOT L 98's Avatar
PM sent!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
