Fender question
Old Feb 4, 2008 | 11:48 PM
Rusty91o's Avatar
Car: 1985 Z/28
Engine: 5.7 TPI
Fender question
Hey all, I'm new to these forums, but not not to Camaros. But anyway, I need to get a new front right fender, and I can't remember or find out if a base model Camaro fender with NO ground effects/skirts will fit for my Z/28 Do I need to get a fender off a Z/28 or can I use a base model fender?? I will be using my current skirts for whatever new fender I get. Thank you In advance..
Old Feb 5, 2008 | 12:06 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: Fender question
i think there all interchangable.
just get one from the wrecker or something. cost you like maybe $50 or something. could be more. no idea what the priceing of them are.
what is wrong with your fender?
Old Feb 5, 2008 | 12:12 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Fender question
i as well also believe they are all interchangable for the most part...only issue is if you get it from a base coupe or w/e w/out the body kit or the older body kit you will have to possibly fill/change holes around to accomidate the body kit you have for the car, thats all.
Old Feb 5, 2008 | 12:17 AM
Rusty91o's Avatar
Car: 1985 Z/28
Engine: 5.7 TPI
Re: Fender question
That's mostly what i was wondering. I know on the Z/28's and all, they have special holes at the very bottom of the fender to allow the FX to clip in. There is a lip that extends from the fender, I just don't know if the Base models have that too. I might just have to see for myself and go look at one. As for the fender, I got my Z/28 last year from a friend who crashed it in the rain and went under a truck. The right front of the hood, and fender are messed up, not horribly, but sure enough to make it look sbad. I need to get a fender and hood. But I'm looking for a Daytona hood for it. Just don't wanna pay for brand new...:/
Old Aug 4, 2008 | 07:21 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
Re: Fender question
Does the camaro have fender vents? My 85 Trans am has fender vents on both fenders!
Old Aug 4, 2008 | 09:15 AM
kcb37's Avatar
Re: Fender question
If you don't get a for sure answer or you want a more definent answer, try calling a few body shops.
As everyone else has said, I think they are all interchangeable.
At the least it should bolt up without any modifications. Maybe some for the trim though.
Old Aug 4, 2008 | 06:38 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Fender question
all camaro fenders are interchangeable, so are all firebird fenders. the only difference between the years will be the mounting holes for the gfx.
MustangBeater20
Oct 29, 2022 09:20 PM
TEEZER TA
Aug 30, 2015 06:35 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
