power windows help!!
Old Feb 15, 2008 | 11:05 PM
kingsflame's Avatar
my windows go down slow and not smoothly and the motor is pretty loud also, i replaced the windows sweeps and weatherstriping..and it still does it...is the motor going bad? or is their a way i can fix it?
Old Feb 15, 2008 | 11:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: power windows help!!
your question pretty much is the solution . loud motor , bad motor . sticking operation bad motor or linkage . when you remove motors check and fix/lube all linkage . not looking fwd. to day i need to do it .
Old Feb 16, 2008 | 06:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Try cleaning and lubing before you start tearing into the motors--you may be surprised at the result (though the windows will always be slow compared to new cars). Since you'll be inside the doors anyway, you may wish to take some other positive measures. Check the following link:
https://www.thirdgen.org/forums/body...servation.html
JamesC
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
