Access Door Question
Old Feb 23, 2008 | 09:46 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I have decided to put a fuel pump access door in my car (please, keep the flaming to a minimum ). Basically, I just want to know if anyone has purchased a good access door or knows where to buy one.
I want to make this look good so I am looking for a nice door that I can rivet/screw into my floor pan. I searched around for a while but couldn't find any retailers of access doors. Any direction would be much appreciated, thanks.
Old Feb 24, 2008 | 08:35 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Re: Access Door Question
I was going to make one, but then I started looking at the size of it. Top middle and then down behind the seat a little and across to the drivers side because of the lines. The pump has to come out and the lines with it. If I am wrong about this then post up!
Old Feb 24, 2008 | 08:56 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Titan, you will most likely have to fabricate and/or modify something similar to what you want. If you or someone you know is handy and has tools and knows how to weld, if needed, it should be easy to do. The easiest thing to do would be to carefully cut out the area you want access to, measure and cut a piece of similar gauge sheet metal and inch or so longer and wider so it overlaps, lay it over the hole, drill a hole in each corner and then install a sheet metal screw in each corner. To keep water or exhaust fumes getting in, if they would be a problem, you could use some self stick weather strip/foam tape around it. Just a thought. Maybe take a couple of hours and go through a salvage yard and see what you could adapt. Right off I think about gas filler doors but they are probably too small. I just remembered our `49 Studebaker Champion had rectangular vent doors inside the car!
Old Feb 24, 2008 | 09:46 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Like this
Attached Thumbnails Access Door Question-show-20car-206-20point
Old Feb 24, 2008 | 10:21 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Nicely done!
Old Feb 24, 2008 | 10:29 PM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
My car just has the floor area cut with the same type of sheet metal screwed over top. It was done before I bought the car but is handy and doesnt look bad at all. The carpet is over it as well so know one can see it anyway.
Old Feb 25, 2008 | 12:25 PM
2fast4u92z's Avatar
It is a Morosso door called "fuel access door". I don't have a pump in there anymore. But still need to get to there in under 10min so I have it.
Old Feb 25, 2008 | 03:41 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Thats exactly the type of thing I am looking for. Do you have enough room with that one to get the fuel pump through?
Thanks for the info jimdutro, I may end up just putting a piece of metal over it due to larger size and smaller price.
Old Feb 25, 2008 | 07:46 PM
2fast4u92z's Avatar
4th gen yes 3rd gen don't know. it realy is a nice piece and has a deuz fitting on it.
Old Feb 25, 2008 | 08:23 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
That door will not work on a third gen unless you cut the metal lines off and find a way to connect them at the tank.
I'd like to see a pic of the smallest access door that'll still let the pump be removed from the tank.
I originally cut the top out of a spare car to make one that overlapped about an inch front and rear (meaning an inch down front and rear into the seat area and the trunk area) and about a foot wide, maybe 14 inches. Then I went and looked at the pump and the lines coming off the top stretches across the top of the tank, past the top, makes a right angle and goes almost to the frame. Lines are long!
And remember that the pump unit has to come out of the tank a ways before clearing the hole.
Personally, I think I'm gonna chop the lines and make a small hole. I see no other good way. I have two sets of lines so I'll post up what I figure out. Prob have to sweat some fittings on the lines and break them at the pump holder.
Old Feb 25, 2008 | 11:23 PM
fenton06's Avatar
just use a circuit breaker door...it looks really good...let me see if i can find that pic somehwere....
EDIT: bwahaha....damn i'm good https://www.thirdgen.org/forums/post...485-post8.html
Old Feb 26, 2008 | 10:50 AM
2fast4u92z's Avatar
That is a 3rd gen with a 4th gen tank. Oh and just so everyone knows I have a custom fabed aluminum cell under the car and there is 1"x1"x1" pading on the top of the tank to make more of a seal.
Old Feb 26, 2008 | 05:08 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Now that looks awesome and large enough to do the job. Thanks for the pics, I will probably go this route since it seems like the best way. Now to find a door
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
