What size welding wire?
Old Feb 24, 2008 | 09:32 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I have access to a MIG wire feed welder so I have been doing a little body work. The question is what size wire do some of you guys use when welding in patches on sheet metal? I have .030 on there now and I think its too big. I can't quite get the voltage where I want it, it's either too high and I am blowing through the metal or it seems too low and its hard to get a arc. Any tips or advice appreciated!
Old Mar 2, 2008 | 12:57 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
Re: What size welding wire?
I would use .023 wire, you can get the heat down lower so you wont blow holes in the sheet metal
Old Mar 3, 2008 | 12:38 AM
UDAMON's Avatar
Car: Mazda Protege5
Old Mar 3, 2008 | 12:34 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Thanks! I figured I needed smaller wire, but just was not quite sure.
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
overdriv
Aug 20, 2015 03:52 PM
knight72
Aug 10, 2015 09:32 PM
