rear hatch won't release
Old Apr 5, 2008 | 05:28 PM
scout1069's Avatar
Car: 1986 IROC Z28
Axle/Gears: 3:23
The motor works as far as push and pull goes, but it won't release the hatch where I can pull it up. It needs new struts, I know that much. Can anyone shed some light on what might be catching and how to fix this damn thing.
Thanks in advance
Old Apr 10, 2008 | 02:41 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Re: rear hatch won't release
the hood of my mom's car got stuck like that, so i just had her hold the hood release open, and then i just pulled the hood as hard as i could, and it opened. but as far as the hatch goes, i wouldn't suggest doing that, i just thought i would share my experience.
Old Apr 10, 2008 | 02:53 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Suggest you get a buddy to help then; Push down as hard as you can against the hatch lid plate (not on the spoiler!) and put the key in the rear hatch key hole, turn key and hold key to un-lock, while keeping pressure on the lid until the lock and latch release. This happened to my Maro, and that's how we got it un-stuck.
When you get it open, you might need to adjust the hatch motor plate. Check it and good luck!
Old Apr 10, 2008 | 02:54 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
this might sound crazy but crawl through your trunk and see if you can see wheres its stuck thats what i had to do when mine broke but i dont have a pull down motor so yours might be different
Old Apr 10, 2008 | 06:08 PM
guitargod2138's Avatar
Car: 1992 Camaro RS
Engine: 305tbi, some bolt ons
Axle/Gears: 3.73 posi
as far as the hood thing goes, same thing happened to my hood, i jsut sprayed some wd40 on the locks and it opens perfectly now...
as far as your hatch motor, mine did the same thing because these teeth things in the motor back there got stuck and then broke when they tried to turn and lock, that may be your problem, if it is your motor is broke and you need to get a new one, i jsut pulled the teeth out, and i manually open and close it now, and it closes great
Old Apr 11, 2008 | 12:16 AM
scout1069's Avatar
Car: 1986 IROC Z28
Axle/Gears: 3:23
Yep I got it unstuck. Thanx for the help. The struts are worn out so there is no pressure to open it.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
