how to remove the paint of a front bumper??
Old Apr 6, 2008 | 04:21 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i got got a new nose for mycar and i wanna snd down and paint it but it has double paint on it and i dnt wana mess up the plastic.by sanding to mch or scratching it...wuts the best way to remove the paint???
Old Apr 6, 2008 | 05:51 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: how to remove the paint of a front bumper??
If the paint isn't cracked anywhere,you can get away with a light sand with 800 grit.If the paint is cracked,you can easily take all the paint off with a d/a and 150 grit paper
Old Apr 7, 2008 | 12:49 PM
905SpeedGTA's Avatar
Car: 1988 Pontiac trans am GTA 5 speed
Engine: 5.0L Tuned Port Injection
Transmission: Borg Warner World Class T5
Axle/Gears: 3:73 Rear
Yes, I had cracks and 10,000 layers of paint on my car.. I used a 150 grit wheel attached to My power drill ( Not Battery operated) and one for my variable speed Wheel Grinder, take your time on that one, I hope you dont have any Cracks... I would use the electric palm sander.. the two tools I mentioned got alittle scary when you get into groves. plus give too muc pressure you may eat a hole into your bumper!.... the fog light holes I had to sand By hand..
Old Apr 7, 2008 | 04:41 PM
easternjane2006's Avatar
Car: 83 camaro Z28
Transmission: th350
I used a 400 and wet sanded then went over with 600 came out really nice no scratches.
Old Apr 9, 2008 | 08:20 AM
vette gator's Avatar
Car: 85 Z28
One caution - don't use chemical paint stripper on urethane. I got a free urethane license plate cover for my Corvette. It had about 6 different coats of paint that were caked in the "C O R V E T T E" letters, so I wanted to strip it down before painting to match my car. Sanding was taking forever, so I used paint stripper. It took the paint off all right, but it also deformed the heck out of the urethane. Since I had gotten the part for free, and it wasn't in very good shape to begin with, I chalked it up to a cheap lesson in case I ever had to strip a urethane part that actually was valuable.
Old Apr 9, 2008 | 09:30 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I thought there was something, maybe SEM bumper stripper? That is safe for use on our bumpers. I think I remember seeing it mentioned on here b4
Old Apr 9, 2008 | 09:33 AM
Car: 85 Z28
I was just using the regular paint stripper from Home Depot. Good to know that there is a urethane-safe stripper.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
