Need help replacing hatch lock cyclinder
Old Apr 16, 2008 | 06:49 PM
86TransAm350's Avatar
Car: 86 Trans Am
Axle/Gears: 2:77
Could someone please tell me where I can find a hatch lock cylinder for a 86 Trans Am. And how do I fix it from the inside?(or outside) I appreciate your help.
Old Apr 16, 2008 | 06:52 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Need help replacing hatch lock cyclinder
Your best bet is the junk yard (make sure you get a key) or place an ad here in the parts wanted section. There is a c-clip that holds it in and you access it from the inside.
Old Apr 16, 2008 | 06:54 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
junk yard or classic industries has them (classicindustries.com). You can even buy an entire new set for your car so they all match. Otherwise, as far as removal:
- remove interior trim over pull down motor
- mark location of 3 pulldown motor bolts and remove the pull down unit
- twist the lock cable on the inside of the cylinder counter clockwise (will look/feel like your going to break but it won't)
- remove the tail lights (at least the center piece)
- get a 1/4" drill bit and drill out the old lock cylinder
- get 2 1/4" rivits from your local chevy/pontiac dealer along with a special big riviter, and install new lock cylinder
that should just about cover it. Looks overwhelming, but it's pretty simple.
he's got a bird duke
Old Apr 16, 2008 | 07:02 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Correct....The Firebird lock cylinders are rivited in whereas the camaro ones are held in by a clip
Old Apr 16, 2008 | 07:14 PM
Car: 86 Trans Am
Axle/Gears: 2:77
Thanks guys, I've found what I needed in about five minutes compared to spending a lot of time reserching.
Old Apr 16, 2008 | 07:18 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
interesting, I learned something new today
Old Apr 18, 2008 | 06:40 PM
Car: 86 Trans Am
Axle/Gears: 2:77
I'm having a really hard time getting that plastic piece off from the inside. I took all the screws off and it won't come off. It feels like something from the other side where I can't get to is holding it. Like right in the middle at the top, where the trunk light in locatated. If anyone has any tips on how to get it off I would appreciate it. Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
