Rust Remove
Old May 4, 2008 | 05:01 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
Welding?
I have a small hole due to rust, Is there an alternative instead of welding?
This is what i'm dealing with...
Old May 4, 2008 | 11:04 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
Re: Rust Remove
if i were you id buy a new front fender ... thats some pretty good rust and it pretty deep... you can get a front fender for cheap and its not that hard to replace...
Old May 5, 2008 | 12:15 AM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
Re: Rust Remove
i agree look around, i found new fenders for 50 bucks a side for my 3rd gen.
but if you could care less and just want to fix it, wire wheel all the rust away, and get friendly with bondo and a sander.
Old May 5, 2008 | 04:20 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Rust Remove
please dont do this, just replace the fenders. if you really are set on fixing them without welding use fiberglass.
Old May 5, 2008 | 10:27 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
Re: Rust Remove
Thanks guys for the help, I think i'll do the fiber glass just for temp see how it comes out, If i dont like the results then i guess i'll just have to go out and rent a welder...
Old May 6, 2008 | 05:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rust Remove
Take off the inner plastic fender liner to verify the extent of the rust--hopefully, you won't be horrified at what you find.
JamesC
Old May 6, 2008 | 07:41 AM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
Re: Rust Remove
Well i took off the fender yesterday, Good news is that there isnt any rust where the fender was at, bad news is the hole got a bit bigger due to my brother losing he's balance and ramming he's knee into it... Wow...
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
TheExaminer
Sep 6, 2015 11:40 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
