removing door mouldings
Old May 7, 2008 | 10:26 PM
FormulaFranco's Avatar
Car: 1989 Firebird Formula 350
hey guys, just wanted to ask u guys how hard is it to remove the moulding strips on the doors, i really like the way the cars look without the moulding, how hard would it be, and how would i remove the glue left on the doors and such?
Old May 8, 2008 | 07:30 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: removing door mouldings
get some thick fishing line
wrap it around both your hands like you were about to strangle someone
leave about 6 inches between your hands and put it under the molding
pull across the molding with slight preasure towards yourself
this is the best way to take off moldings and emblems that are taped on
if you can buff!!! soak the glue with a rag soaked in laquer thinner
scrape with a plasitic razor blade and buff
if you cant buff tell everyone your wont see them all weekend
Old May 8, 2008 | 12:23 PM
thank you very much that sounds easy enough to follow
Old May 8, 2008 | 12:44 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You may not even need the fishing line. I just grabbed mine and pulled. They fought me, but I won. I haven't removed all the tape yet, but some Goo-Gone should work too. Might cost more than lacquer thinner, but its safer to breathe if your doing this in a small garage like I am.
Old May 8, 2008 | 05:05 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I did this same method except you may want to put some leather gloves on...
Old May 8, 2008 | 05:06 PM
would my mecanix golves work or should i put on the welding gloves lol
Old May 8, 2008 | 05:08 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
mecanix gloves should be fine, you just need something to keep from getting cut, I found that out the hard way lol
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
