How much does the body shell weigh?
Old May 15, 2008 | 11:14 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
I have a stripped body shell I want to make a dolly for so I can move it around while I do the body work and I want to make sure whatever I build is strong enough. Anyone know how much the body shell by itself weighs?
Old May 18, 2008 | 10:22 PM
69-er's Avatar
Re: How much does the body shell weigh?
Since no one has answered, I thought I would try to give you a ballpark value. Better than nothin', huh?
My 69 Camaro bare shell weighs 600 lbs. The 3rd gen might be a bit more since there is the body structure forward of the firewall to consider.
Larry
Old May 18, 2008 | 11:25 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
yeah, I was thinking about 800-900 pounds but I don’t know, It’s sitting on 4 jack stands now and I can lift up the front but it may just be the way its sitting on the rear jack stands.
Old May 19, 2008 | 10:09 PM
69-er's Avatar
Well, hey, if it's stripped down now, just beg, buy or borrow some bathroom scales. They will probably have the capacity to weigh all four corners. That's how I weighed mine.
Larry
Old May 20, 2008 | 09:20 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I'd guess no more than 700 lbs... 3rd gens weigh about the same as first gens and the unibody doesn't really add much weight to the shell.
Last edited by ChillPhatCat; May 20, 2008 at 09:21 AM. Reason: Automerged Doublepost
Old May 21, 2008 | 05:48 PM
sixpackmtrspts's Avatar
heres a pic of mine that i built. i just used some 2x3 box 1/8th inch and welded the cart up. i welded some bolts into the end of the 2x2 box risers to fit into the factory locating holes in the subframes. simple and makes it moveable.
Old May 21, 2008 | 08:06 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
wow sixpack thats a sweet setup you got there. Good job.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
Kenwood
Sep 4, 2015 05:50 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
