bumper cover too head light panel?
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
hey guys, i have my car primed now and i was just block sanding the front bumper cover and i noticed that the recessed area for the head lights is not flat by any means. now there is some plastic tabs that go from the bumper cover to the head light bar, do those tabs go under, or on top of the plastic part of the head light bar that they mount to? they are on top of it now but the plastic mounts are bent in a way that looks like they should be under. but if i put them under, it does not look like the holes for the bolt will line up? any help would be great, any pictures may help too. thanksDavid
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
Re: bumper cover too head light panel?
While looking at it from the underside, the bolts that go through the bottom of the headlight bar go into the bumper which has those nuts that clip onto the panel. so in a sence, the bumper goes on top of the headlight bar(as far as the tabs go)
Car: 88 iroc camaro
Axle/Gears: stock
hay man, thanks for taking the time to crawl under the car and look. that is the way i have it now!
Engine: 406, 305
It wasn't even that much trouble since i just put my headlight bar back onto my bumper a couple hours before I posted! But your welcome, glad I could help.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
