Trying to get rocker panel off w/o damage
Old Jul 2, 2008 | 05:08 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I did a stupid thing recently, I let the hydraulic jack slip off its lift point and crush the rocker panel from below.
I have a 1987 IROCZ. How do I remove this rocker panel w/o damaging it any further? I have remove the hex head screws that go in from bottom side and I have remove the four phillips screws that you see when you open the door. There still remains some sort of a connector in the rear of the rocker panel and another one up front near the front wheel well. I have the '87 shop manual, but do not see any help on this matter.
How do I get the rocker panel off of these pins or connectors?
Old Jul 2, 2008 | 07:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Trying to get rocker panel off w/o damage
Two screws under the Z28 emblem at the front. You'll have to remove the rear interior panel at the back (the one that has an arm rest). The two nuts are behind a square rubber panel that you'll have to peel back.
JamesC
Old Jul 3, 2008 | 10:34 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
JamesC: thank you for the response.
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
New2Chevy
Sep 28, 2015 12:35 AM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
Stryker412
Sep 7, 2015 09:11 AM
