weatherstripping track
Old Jul 7, 2008 | 06:50 AM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
does anybody know the proper name for the piece that holds the weatherstip by the quarter panel on a t-top camaro.it is about 10 -12 inches long and has a plastic coating that is peeling off of mine .I am trying to replace mine but cant find them.GMparts direct has some q-panel parts but they dont show pics so I need to know what GM calls it .
thanks MikeT
Old Jul 7, 2008 | 08:10 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: weatherstripping track
Are you asking about the two metal t-top weather strip retention strip's that are mounted (screwed) to the body? If so and your trying to find new ones, good luck. I recently tried to purchase brand new replacements from a GM parts dealership, they're discontinued.
Are yours bent or in some way non-re-useable? I harvested a good pair from the wrecking yard, cleaned them up (pain in the a**) and painted them. Good as new for less than $20 (paint included).
If you want new, might ask a couple of the sponsers on this site if they have them?
Good luck
Old Jul 7, 2008 | 11:19 AM
Car: 92rs
Transmission: 350
yeah that is what I am looking for.tried all the sponsors ,no luck.
how did you clean yours up?the coating is peeling off mine but what is left is on there prettygood .
I would be happy removing the coating and painting mine if I must ,though I was looking for a bolt-on fix.
any suggestions are appreciated,thanks for the fast response.
Old Jul 7, 2008 | 01:15 PM
Wadebryant's Avatar
Cleaning took time and a lot of elbow grease. To remove the sealer / adhesive I used my heat gun to soften up the materials, then with wooden and plastic picks scraped away as much as would come off. Some of it wouldnt so I hit that with a small brass polishing wheel attached to a dremel tool. That works pretty well and doesnt scratch things up.
Once the adhesive was pretty much gone, I used 320 wet / dry over all surfaces then followed by degreaser and mineral spirts then 600 w/d before painting. Sounds like a lot of trouble but that's how I went about it. Turned out real nice and the price was right.
Good luck!
Old Jul 7, 2008 | 02:41 PM
Camarogeddon's Avatar
Car: '85 Camaro Z28
Engine: 350 carbed.
Axle/Gears: 9 bolt, 4.11's
I believe the part you are talking about is called a drip rail.
best bet is as mentioned earlier to refinish what you have, or search for some good ones on a junkyard.
my car was missing one of these, and it took me quite a while to locate one.
(main problem was getting various vendors to actually understand what i was trying to get.. hawks sent me a weatherstrip for a hardtop, while i ordered the drip rail for a t-top car....)
Old Jul 8, 2008 | 03:54 PM
Car: 92rs
Transmission: 350
elbow grease it will probably be.
thanks for the tips
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
