T-Top Adjustment?
Old Aug 8, 2008 | 02:41 PM
Bolly1965's Avatar
Car: 1989 Trans Am
Engine: 5.0L
T-Top Adjustment?
Forgive me if I'm being numb, but there's not a lot of info here in England.
My T-Tops leak - what a surprise. The car has had new seals and it still leaks.
I was wondering if the locking holes on the car body are adjustable to tighten up the seal? There seems to be a screw below the holes and I wondered if that was how they are adjusted (Didn't want to try it and make things worse!)
Old Aug 8, 2008 | 09:30 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: T-Top Adjustment?
Well ive never had mine off but seen it at a junkyard. I think you got to take your A pillar off by removing that screw below the holes and then get the push in clips out to take the pillar all the way off. then there should be two bolts behind there holding the T-top pin mounting plate on. Loosen them and adjust it. So pretty much take your A pillar off and the rest should be self explanetory.
Old Aug 9, 2008 | 02:33 AM
Bolly1965's Avatar
Car: 1989 Trans Am
Engine: 5.0L
Thanks for that - i'll give it a go - when it stops raining!
Mark_ZZ3
May 24, 2018 01:02 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Nervous2
Oct 8, 2015 10:53 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
