1986 Trans Am project starting plans
Old Aug 24, 2008 | 11:48 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Ok everyone, this winter I will be taking apart my car piece by piece for the restoration going to be done to it. The floor pans are horrible from what I can see from looking under the car. I will be ordering all replacement parts from Classic Industries, unless there another place someone has in mind. I just wanna know what I should be looking out for when taking apart everything. I will put pics up after I start (which will be in the winter)
Old Aug 25, 2008 | 06:11 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: 1986 Trans Am project starting plans
if you cant just patch up the floor pans then obviously becareful of fuel lines and anything with the transmission directly underneath.
i wouldnt want to repalce the entire floor but hey go for it if u have the time and money and have no other choice
Old Aug 25, 2008 | 07:40 PM
Engine: 350/350/LS1
Its not that I dont have time/ money I just want it done right and complete
Old Aug 25, 2008 | 07:51 PM
Bobby_80s's Avatar
Axle/Gears: no idea
yes i agree jsut you dont see the floor. its good you want it done right and to look good. just theres mroe than one way to have a floor pan.
and like i said its depends on time and money and i should of added how far you personally wanted to go with it.
like me personally i would just patch it up unless it was truly rotted and gone.
but no judgment just be aware of what is underneath when you cut out and weld in the new floors
goodluck hope its everything you want it to be
Old Aug 26, 2008 | 10:26 PM
Engine: 350/350/LS1
So after welding everything in, Is there a paste or whatever that goes on the metal so it prevents rust?
Old Aug 26, 2008 | 10:54 PM
Bobby_80s's Avatar
Axle/Gears: no idea
yes, not sure what its called, try a local autoparts/autobody store or last resort someone at a dealership in the parts dept. might be able to tell u
Old Aug 27, 2008 | 12:59 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Make sure you use weld through primer before you start welding. That should prevent the welds from rusting.
Old Sep 1, 2008 | 09:40 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
there is some stuff thats called sp-15 or pr-15 dont remember ill look into it and get back to ya but its a paint that when it dries is kinda like powder coating and it prevents rust and its really durable a friend of mine did his suspension parts in it and it hasnt chipped.Or you could just go with spraying primer down just anything thats rust resistant
Old Sep 1, 2008 | 10:39 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
POR-15, I have heard nothing but good from people that have used it (to instructions). got to pick some up when i finish my firewall.
Old Sep 1, 2008 | 10:51 PM
Engine: 350/350/LS1
K thanks, That will be just for the body then when reconstructing it, Wat bout takin it apart
Old Sep 2, 2008 | 09:24 AM
madhatter's Avatar
por-15 works great if you prep first, you must scuff the surface or it will peal up other than that it is solid. taking every thing appart is really the easy part, now put things back together now thats a pain. my suggestion is that you go buy sealable baggies and mark them for what you are taking apart. label them very well and try to keep all the hardware for one particular peice in that bag, and get one specific box to put all the screws in. i am in the process of a full resto on my car and there is nothing in it. i didn;t do the best job keeping things organized and now i am kicking myself in the ***, because it is hell trying to find what i am looking for. do yourself a favor and organize
my
Old Sep 2, 2008 | 03:41 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
you should seam seal the welds before applying the paint, I personally would use rust bullet.
Old Sep 2, 2008 | 04:45 PM
87transGTA's Avatar
Car: 87 GTA
yeah that crap lol yeah that stuff is amazin i had a tiny *** can and it lasted forever
Old Sep 16, 2008 | 10:02 PM
cpears's Avatar
Car: 1988 IROC
Transmission: TH-700r4
Make sure you use very very good ventilation when working with POR-15 the stuff is awesome, but can damage your respiratory system.
Old Sep 16, 2008 | 10:11 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Only if you spray it.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
L98GTA87
Aug 5, 2015 11:02 PM
