Door hinges...not the lower door pin this time
Old Aug 28, 2008 | 08:58 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I was trying to figure out where the play in my door is coming from and finally found it to be the upper hinge of the door. There is just a slight amount but enough so the door gets caught up on its swing if its opened all the way. What can i do about this? Is there supposed to be some play in that hinge? Does this door just needs to be readjusted or do i need to yank the door and replace that upper hinge?
Old Aug 28, 2008 | 12:10 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: Door hinges...not the lower door pin this time
Common problem, you need to replace the upper hinges and bushings. Check these out, worked great for both my doors.
http://www.top-downsolutions.com/pro...products_id=37
Old Aug 28, 2008 | 12:42 PM
subroc's Avatar
Engine: 355 TPI
Wow that is some expensive stuff. I already have the lower bushings and hinges as well as some smooth bushings that look like they might be for the top. Not sure as these came with a former car and ive just held on to them.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
BlackTopKing
Aug 19, 2015 12:13 PM
