Door & Glass fitment
Old Sep 4, 2008 | 04:49 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
in the next day or two i will be swapping doors from a t top car to a non t top . are there any issues with the glass fitting ? both doors are power , donor is an 89rs , recieving is an 88s/c . any advice on door alignment ? just trying to head off any issues before i get into it . yes i did a search , just feeling for any personal insight . all and any advice on this chore is welcome . thanks for any help .
Old Sep 4, 2008 | 05:25 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Door & Glass fitment
doors/glass are identical. no foreseen problems other than aligning the door properly...
Old Sep 4, 2008 | 05:51 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
door and glass no prob.
88s/c=no gfx
89rs=gfx
gonna fill those holes in on bottom of door or you already have gfx?
Old Sep 7, 2008 | 09:10 AM
UNCLE TOM's Avatar
no one has any helpful hints , points , info. on replacing doors ? i know some of yall have done this . HELP !!!
Old Sep 8, 2008 | 10:34 PM
madhatter's Avatar
take the fenders off, it makes it easier to get to the bolts. close the door and the start putting the bolts in. easier to do this with the doors closed than having someone hold them up. get some bolts snugged and then open and close the door to make sure it opens and closes good, and also check the door gap to the rear quarter. then put the front back together, keeping the fender gaps equal to the rear gaps, and making sure it still opens and closes freely. I'm not sure if other guys do it with the fenders still on but i think that it is easier to do with the front off. more work but not hard to do
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
F-body-fan
Sep 24, 2015 08:29 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
