adding iroc gfx to berlinetta
Old Nov 7, 2008 | 02:32 PM
chevylove87's Avatar
Car: 87 camaro
Transmission: 700r4 shift kit
i have an 87 berlinetta and i was wanting to know what would be the easiest way on mounting them to my car
Old Nov 7, 2008 | 07:34 PM
Car: 87 camaro
Re: adding iroc gfx to berlinetta
no the actual ground effects off of an iroc putting them on a base model not decals and i bought the car for 500 dollars
Old Nov 8, 2008 | 07:24 AM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
Being 100% honest here, the guy I bought mine from scammed me years back, short of going down to PA to blow his door down and hang him upside down from his manhood, I recieved most of the ground effects, but didnt recieve the mount hardware from him. I then made some sheet metal brackets and used 5/16" zip screws, worked great.
Old Nov 9, 2008 | 09:20 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
First; Your car is an 87 - It's not a Berlinetta. With that out of the way,.......
Take a look at this picture:
The 2 braces at the bottom of the pic are the kind you will need - or need to make - in order to install Ground FX on your Coupe. (Disregard the braces at the top of the picture - they are for a Trans Am.) The brackets are factory F-Body brackets that can be used on ALL 82-92 F-Bodies. ( they ould need to be trimmed for use on the 91-92 Ground FX )
I might still have an extra set of them; If your interested in buying a pair just send me a PM with your ZIP CODE. I'll dig around later today to see If I can find a pair.
Old Nov 11, 2008 | 08:20 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I Have a set of those metal brackets needed to mount GFX to your car, LMK as well.
Old Nov 11, 2008 | 09:28 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
The brackets pictured above are for the rocker panel mouldings. The door mouldings go on with nuts on the studs that stick thru the door. You need to spend some time carefully laying out the holes and then drill them. Fenders are about the same. If you are taking them off the donor car yourself, you have the best chance to get them on properly.
Old Nov 11, 2008 | 10:10 PM
Car: 87 camaro
alright thanks
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
bbernardo94
Aug 19, 2015 05:25 AM
mustangman65_79
Aug 11, 2015 03:17 PM
