need some help w/ my hood latch
Old Nov 22, 2008 | 10:41 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
its sticking really bad. I need to adjust my height. so I shut the hood to see how much I needed to adjust it and now it won't open up! I had just adjusted the hood latch itself because it wasn't latching and now I'm getting the opposite effect. please help. I really need to get this done.
Old Nov 23, 2008 | 07:57 AM
Pocket's Avatar
Car: 91 Trans Am
Re: need some help w/ my hood latch
If you crawl up under the nose you can manually pop it
Old Nov 23, 2008 | 12:44 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Sometimes it takes 2 people to get it open. Have someone pull the handle while you pull up on the hood. Try pushing down on it while you pop the latch. And the handle has to go back in for the latch to fully release. When you get it open adjust it as close as you can and grease it before you close it again.
Old Dec 29, 2008 | 04:14 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
my hood got stuck once
it got so I had to jack up the drivers side of the car from the a-arm and produce enough body twist that the hood finally popped open
Old Dec 30, 2008 | 12:54 AM
madhatter's Avatar
second that one, haven't finished the car yet so thats how i do it works like a charm
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
