Changing air vents on T/A fenders
Old Dec 9, 2008 | 05:36 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Anyone have some hints/tips on the easiest way to change the fender air vents on my 89 T/A?
The drivers side vent must have some broken tabs as it not flush with the body.
Thanks in advance.
Old Dec 9, 2008 | 11:57 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: Changing air vents on T/A fenders
you have to first remove your lower ground effects panel. After it's off, there are spring clips that hold the fender vent into the fender. Remove a couple of the rear-most clips that hold your wheel well liner in and you can reach in and feel around the side of the fender vent for the spring clips... push them in towards the plastic fender vent and pop the vent out of the front of the fender.
Old Dec 10, 2008 | 04:19 AM
Car: 89 T/A
Engine: LB9
Thanks for the info Jeremy,much appreciated!
Old Dec 11, 2008 | 10:29 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
EDIT...nevermind. I should have read more carefully...
J.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
