will a 91-92 front fender fit a 89 rs.
Old Dec 18, 2008 | 01:43 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
nd 91-92 doors and fenders. i was looking in a parts book and they are always a different part number. i was thinking maybe the body line on the door is different.
Old Dec 18, 2008 | 02:51 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: will a 91-92 front fender fit a 89 rs.
i would think so, doors, frnt bumper and hoods are interchangeable as far as i know.
Old Dec 18, 2008 | 03:13 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
it should fit fine
Old Dec 18, 2008 | 09:43 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
i was thinking it was the body line where the door meats the fender was in a different spot. i couldent understand the two part numbers. 82-84 is another part number. but the bolts are all in the same locations?
Old Dec 21, 2008 | 09:03 PM
nd2bfstr's Avatar
Car: 91 camaro
Engine: 434 sbc
Transmission: powerglide
Axle/Gears: 9" 4.56
only difference is the holes in the gfx on the lower fender and door lwr gfx. 85-90 has bolt holes all down the lwr gfx on the front fender. the 91 has a tab that needs a slot cut open for the gfx or grind off the tab its around 1/8" by 3" long .the door has different mounting holes because of the shape of the gfx a little work but will fit
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
kyleb24
Aug 15, 2015 08:24 AM
Amillionoh7
Aug 7, 2015 01:24 PM
