Window felts
Old Jan 7, 2009 | 04:25 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Window felts
Hey guys, thought I'd tap into your resourcefulness and pose a question. I have my driver's side door panel off to lubricate rods and such, left it off because I'm considering replacing the window motor...but that's not the problem...I go out to my car and find the rear window felt adjuster twisted at an odd angle. I go to touch it and the whole thing snaps off in my fingers, metal and all...this piece doesn't look like it would be as strong welded back in place, or would it be?
Tell me what I should do please?
Old Jan 7, 2009 | 04:39 PM
popballz's Avatar
Car: 89 firebird
Re: Window felts
is the bracket big enough to drill a hole behind the big hole?
the red dot in the attached pic
Old Jan 7, 2009 | 04:50 PM
lasher_350's Avatar
Engine: 5.7 L98
Re: Window felts
There is indeed room at the rear of the bracket, but not enough room to make it adjustable. so it would be a "one position only and hope it's the right position" kinda thing. If all else fails, I might try that.
Old Jan 7, 2009 | 11:37 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Window felts
You could certainly reinforce the area when you weld it back in. Shouldn't be any problem at all.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
gord327
Oct 3, 2015 01:25 PM
kkirch15
Sep 30, 2015 04:44 PM
