Rear Hatch...
Old Jan 19, 2009 | 05:47 PM
1990Camaro1990's Avatar
Car: 1990 Camaro RS
Axle/Gears: not sure???
Rear Hatch...
is there a special way to adjust it? if so... HOW???
also other problems with my car in the engine posts, electrical posts, and transmission posts...
Old Jan 19, 2009 | 06:31 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Re: Rear Hatch...
I don't think you can adjust it. What is the problem you are having with it?
Old Jan 20, 2009 | 04:47 PM
Car: 1990 Camaro RS
Re: Rear Hatch...
Well,
Well, the spoiler on the hatch itself sticks out approximately an inch further
Well, the spoiler on the hatch itself sticks out approximately an inch further out than the other 2 pieces to the spoiler, i didnt know if i could just adjust the hatch or not...
Last edited by 1990Camaro1990; Jan 20, 2009 at 04:48 PM. Reason: Automerged Doublepost
Old Jan 20, 2009 | 05:13 PM
hot92RS's Avatar
Car: 92 Z-28
Re: Rear Hatch...
If it is not closing all the way, the bolts that hold the unit to the body can be adjusted by loosening them and sliding them down-the bolts are through slotted openings. Other than it not closing your hatch all the way, it is functioning properly, right?
Old Jan 20, 2009 | 08:35 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Rear Hatch...
There is some adjustment on the hinges both at the body and at the glass. There is also adjustment where the metal deck lid bolts up to the glass but it is also urethaned to the glass so moving it there is mostly out of the question. Look at the decklid where it meets the quarter panels and see if it lines up there. And check the gaps on the sides and see if they are even and close to the same. My guess is it's probably your spoiler not your hatch. If you want more help post a pic of the problem areas and we can get a better idea of what you're looking at.
Old Jan 21, 2009 | 04:20 PM
Car: 1990 Camaro RS
Re: Rear Hatch...
My hatch is closing correctly
Ill take pictures soon, probably this weekend when i have time
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
