Diff in quarter panel skin and panel?
Old Jan 23, 2009 | 10:31 PM
paveuk's Avatar
I've got a 91 camaro. And I am looking for a new driver side quarter fora few reasons. i am shaving the gas tank door and there are multiple dents (big dents) on some pretty hard body line. I'm having a hard time fixing them so will just probably replace it. Anybody know where I can get a quarter panel and what is the the diff in a quarter skin and a quarter?
Old Jan 23, 2009 | 11:44 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: Diff in quarter panel skin and panel?
Numerous companies are around that sell quarters, goodmark, classic industries, and year one are a few. From what i see in the classic industries book a quarter skin does not have the extension going up to the roof. Where a quarter panel does hope this helps. Also where do you plan on putting the gas tank door?
Old Jan 24, 2009 | 12:03 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
do any of those companies mentioned above sell 82-83 quarters?
Old Jan 24, 2009 | 12:15 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Classic industries advertises them as 82-92 lh and rh now the book im looking at is older and it shows the price as 99.99 ea, So there may be a increase in price from what i have.
Old Jan 24, 2009 | 07:31 AM
Brennan's Avatar
well if i had to geuss id say there are stamping the 84-92 ones with the more rounded fender lip/flare thing
Old Jan 24, 2009 | 05:53 PM
redfivexw's Avatar
A quarter panel skin will only have the outer sheet metal and will need to be welded all the way along the top and sides, then filled. A full quarter panel will go inside the hatch area, inside the door jamb, etc. The full quarter is much less bondo, grinding, welding. The skin is cheaper to buy, more work to install.
Old Jan 24, 2009 | 08:59 PM
paveuk's Avatar
Well i'll probably get a new skin since they are pretty cheap. I'm planning on either routing the gas filler under a hinged license plate or I just might use a fuel cell.
jrdturbo
Mar 31, 2016 02:58 PM
kkirch15
Sep 30, 2015 04:44 PM
Vincent135
Sep 28, 2015 10:50 PM
