Rear Hatch Panel
Old Mar 1, 2009 | 09:19 PM
GT150's Avatar
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
Rear Hatch Panel
The body panel that is bolted to the rear hatch on my car is out of alignment. It is positioned too far to the left. This panel is held on by several nuts and I need to know if you have ever taken one off? Is their a seal under it that I might ruin if I take it apart? What torque do the nuts have to be when they are reinstalled? I don't want to break my back window.
Any help will be appreciated
mike
Old Mar 1, 2009 | 10:33 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Rear Hatch Panel
https://www.thirdgen.org/hatchalign
Follow The Tech Article.
Lon
Old Mar 2, 2009 | 07:20 PM
GT150's Avatar
Car: 1988 IROC-Z
How tight do you tighten the bolts that hold on the rear panel onto the glass? If it is pinching the glass could you tighten too much and break it?
Also can you use a heat gun to soften the seal and slide panel into position without ruining the seal?
Mike
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
