91 gfx on a 82
Old Mar 2, 2009 | 09:36 AM
screeminchicken's Avatar
91 gfx on a 82
Has anyone try to put 91-92 aero gfx on an earlier car.
I tried test fitting the rocker panel piece and looks like the gfx is about 1" to 2" shorter than the rocker.
The car is a 82. anybody else run into this issue. I thought pontiac never changes the size of the unibody b/w 92 and 92.
any insight is really appriciated.
Old Mar 2, 2009 | 10:02 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: 91 gfx on a 82
the rocker panels need the bracket that extends out to bolt the panels on
might need to replace the bumpers with 91-92 not sure of how it would look without the 91-92 style bumpers
i wouldnt do it unless your ready to paint the car
trying to do this kind of mod is tricky unless your going to sand down and repaint anyway
Old Mar 2, 2009 | 12:22 PM
Re: 91 gfx on a 82
I have those pieces you are talking about. I am planning on repainting the whole car.
The length I was refreing to id from the front of the rear wheel whell to the back of the front wheel well.
I will take some measurements today and post up some pictures for clarification.
Old Mar 2, 2009 | 12:27 PM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: 91 gfx on a 82
no measurements need to be taken just put on the 91-92 bumpers
drill holes into the fenders and doors for the ground effects bolts bolt them on
no measurements r needed just line up the bolts to see where to dril the holes
82-92 same frame same fenders etc.. just different bumpers and different holes to bolt different style ground effects thats it
and atttach that adapter brackets for the rockers and your all done!
Old Mar 2, 2009 | 01:01 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: 91 gfx on a 82
I have 91 gfx on my 82 you will need to make new holes for the brackets that connect the rear quarter gfx on but that should be it
Old Mar 3, 2009 | 04:01 PM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Re: 91 gfx on a 82
I put the 91 aero gfx on my 87 bird. I had to swap the spot welded bracket on the rocker from the aero car to attach them along the side but other than that and a few other holes that needed drilling everything was straightforward
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
snakeshooter
Sep 7, 2015 11:15 AM
LittleFranks
Aug 20, 2015 03:55 PM
