Front bumper cover.
Old Mar 6, 2009 | 06:17 PM
Miles87Z28's Avatar
Car: 05 Pontiac Sunfire, 87 Z28
Engine: 2.2 Ecotec, 350 TPI
Transmission: Auto, 700r4 with shift kit
Axle/Gears: No clue, limited slip.
Front bumper cover.
I'm trying to remove my front bumper cover to add a coat of primer to it but i can't get to the last to bolts at the top of the inner fender. So i guess the question is should i have removed the front fenders or am i doing something wrong?
Old Mar 6, 2009 | 07:51 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Front bumper cover.
why do you want to remove the bumper only to primer it?
Its not neccesarry.
Old Mar 7, 2009 | 12:59 AM
toomany's Avatar
To get the fenders off, you need to take the bumper cover off (or with the fenders). That top one is the hardest to get. I use a 1/4" ratchet with a 10mm deep socket. Going in from the bottom makes it a little bit easier. Although it can be done from the top. Reaching in from the hole looking down at the side marker light. To get at it this way, a couple extensions are needed...unless you like having your arm bent around backwards.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
3tas4me
Sep 4, 2015 01:45 PM
mikey8494
Aug 22, 2015 07:57 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
