Lower door seals/weather stripping
Old Mar 15, 2009 | 09:43 AM
florida_gators's Avatar
Car: 1990 Firebird
I ran across a couple of these for $30 and was debating whether to buy them. I've heard they were an option, but never came with my Firebird. Do these snap along with the bottom of the door weather stripping? Has anyone tried using these? I'm trying to visualize how they'll look before buying them, so any pictures would be great.
My main reason for buying them isn't for water proofing, since my car is garaged. Despite fixing my doors best I can, there is still some very minor scraping on the body being caused by the door. Will these seals help prevent this? My understanding from the seller is that they will stick out a little from underneath the door. Will this buffer the very minor scratching that the door is doing since it is a little unsmooth?
Thanks. I'm just unfamiliar with this part.
Old Mar 15, 2009 | 09:51 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Lower door seals/weather stripping
If we're thinking of the same part, they're a thin (maybe 1-1/2 inch) rubber strip with slots cut into it. It attaches between the door panel and the door at the bottom. The little christmas trees that hold the door panel on go through the slots in the strip. It will hang down an inch or so below the door panel. They were included with some of the higher end interiors. Probably more of a sound deadener than anything else. Oh picks are here, first couple of posts:
https://www.thirdgen.org/forums/body...servation.html
Old Mar 15, 2009 | 09:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
After looking at mine, I'd say that they won't help at all.
JamesC
Old Mar 15, 2009 | 05:52 PM
bigstack10's Avatar
Car: 92 Camaro RS
Engine: v6 3.1
Did you find them online? if so, where at
i need them for weather purposes, i took my car to the automatic washing machine and got soaked from my passenger window
Old Mar 15, 2009 | 06:37 PM
JamesC's Avatar
The above won't help with windows.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
