need advice on weatherstripping
Old Mar 27, 2009 | 11:54 PM
jeffyjeff06's Avatar
Car: 1984 camaro z-28
Axle/Gears: stock
i have an 84 z28 all the weather stripping except the hatch needs to be replaced i found a good price on all but the window sweeps and my car has the seperate pieces for the front of the windows where is the best deal on getting inner and outer sweeps and the half arrow pieces(think they are called window fillers)
Old Mar 28, 2009 | 01:06 PM
madhatter's Avatar
Re: need advice on weatherstripping
check out hawks thirdgen, ecklers camaro, and a few other. i bought different peices from different companies depending on who had it the cheapest
Old Mar 29, 2009 | 03:10 AM
Axle/Gears: stock
great job i wish i could do body work but money and time are hard to come by right now my car is my daily driver so i changed my mind and i'm gonna hold off on the weather stripping for now since i need to get the rear main changed and i got some exhaust leaks so next i'm gonna true dual it header back the place i talked to quoted me 400 for ehaust installed so i'll get it done soon i'm sure just gotta make sure i can be without the car for that time.
Old Mar 31, 2009 | 11:35 AM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
I am in the process of making my own outer window sweeps - total cost $11. I couldn't find a set for under $60, and that wouldn't fly with me. I grabbed a 12' aluminum carpet bar (cut two pieces the length of each door) and two 4' rubber cove base moldings (cut to door length/sweep width) from Home Depot and join them together. Paint the aluminum if you wish, use some self tapping screws to mount to the door and you're done.
Attached Thumbnails need advice on weatherstripping-sweep1.jpg   need advice on weatherstripping-sweep2.jpg
Old Apr 2, 2009 | 10:40 AM
1Aauto's Avatar
Former Sponsor
PM Sent
Old Apr 2, 2009 | 09:18 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
I bought all that from 1A auto. Fitment was great on everything just take your time.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
