Door Hinge Top Pins
Car: 87 firebird
Engine: 2.8 MFI
Door Hinge Top Pins
Hey there,
I'm in BC, Canada and am trying to do my 87 Firebird top hinge bushings and pins. I got the bushings from the local Lordco parts store but they can't seem to be able to supply the replacement pins ?.
Is there no standard replacement pins for that or do I have to go to GM to get these ?.
Thanks in advance.
Thanks in advance.
Car: 87 firebird
Engine: 2.8 MFI
Re: Door Hinge Top Pins
I was hoping to just go pick some up locally and install this weekend.
I heard that the pins should only cost a few bucks.
I have the bottom set, but can only find the top bushings in the local parts store (no pins).
I will try Canadian Tire tonite
Axle/Gears: 3.45, 3.27, 3.27
I don't know who sold you upper bushings only. You might want to return those. The upper hinge pins are swaged in and can't be removed without destroying them. There are two solutions for repairing the upper hinge pins. GM's solution is to replace the entire hinge which requires drilling out the welds that hold the door half of the hinge to the door. Then you drill holes usinng a template they provide and mount them using screws that thread into a threaded plate that you put inside the door.
The second solution is to use one of the aftermarket hinge repair kits. These require you to grind off the head of the old pins and push them out. Pop out the lower hinge pin, then with the door supported from below retract the door enough to remove the hinge bushings. Install new upper and lower bushings, put the door back in place and install the upper and lower pins. You can also do it by removing the door and service the door while it is on the floor, but you have to un-wire the door which takes longer. I'm supplying info on the hinge repair kits I sell.
http://www.top-downsolutions.com/pro...products_id=38
http://www.top-downsolutions.com/pro...products_id=37
Lon Salgren
Lon Salgren
Car: Camaro 1987
Engine: V6 2.8l MPFI
Hi, what happens if u remove the upper hinge complete, and put a lower hinge there, a pair of lower hinges in junkyard about 10-20 dls, the pins 10, would this work?
Car: 87 GTA
Car: '82 Z28
Engine: 305 LG4
Transmission: 200c
I ordered the hinge repair kits from Automotive Hinge Solutions and had my body shop guys install for $60.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
